Basic Set Of Parallels
kennyv
Mar 10, 2015
309
finally had some time after needing to do maintenance work . Had a few projects all goin on at once so fig id finish this one so I can work on needed mods for the machines. Hers is a set of parallels for my 5” Homge vise to use on my new PM932 . . Nothing special needed a wider set . Started out with a pc of unknown stock , fly cut cut blanks face milled started out ½ thk was going to make .437 didnt likem ended up millin down again settled with 3/8 thickness. They are only within .0005 in the heights in which I did surface grind. Was going to make a nice wooden box but than saw I had this box that would be perfect to house them. Little cut foam/ rubber hot clue done deal. Well that’s about it on to the next project for the mill
DSCF1247.JPG DSCF1355.JPG DSCF1382.JPG DSCF1384.JPG DSCF1385.JPG DSCF1387.JPG DSCF1389.JPG
nice work. That is one thing that a surface grinder is a nice addition to a hobby shop. Wish I had one.
What your charge for another small set. Those look nice.
Thanks KD I dont hav the surface grinder home, did that op at work b/t parts/ jobs .
KVT lol Yea thanks u know it dont work that way still waitin on my oilier cans
And Bob …... no .. not yet .I knew someone would ask heres what hap .I stared with a pc of unknown material that I though was tool steel … had a bear machining It too .. By the end of project it seemed not as hard as I anticipated and realized yea i have to harden them now if they are goin to stay in good shape.. so its on my to do list as soon as I do my first / next harden project .
Ohh the finish is a sorta of burnish u use grind compound and a wood dowel. .. I didnt have grind compound so I tried rubbing compound which I guess did ok.. I knew I was gona rework the finish when I hardened them so just hurried the finishing on the project to be done with for now .
