- Oct 28, 2020
- 543
Appears to be a thin washer. Whats the best way to hold it in a V-block,?Place the disc in a v-block on surface plate, adjust scribed line to vertical using machinist square on surface plate, scribe horizontal line using surface gauge on plate. Centre can be established by measuring diameter of part using micrometer or calipers, then height gauge down 1/2 of that dimension from the top of the disc as it rests in the v-block.
I don’t know about best way, but I might try backing it with a short stub of material to try to get it stay vertical. Failing that I might lay the thin disc flat on a plate and work the v-block standing on its end and see if I could get at it that way. I didn’t see that it was a washer to begin with, for some reason I was thinking it more depth to it.Appears to be a thin washer. Whats the best way to hold it in a V-block,?
