- Aug 21, 2023
- 153
In 1978 I purchased a new Taiwanese built Rong Fu cut-off band saw. . That had a 4” by 6” capacity and a 1/2” blade. It had no issues for 25 years of use. I made a work station table so it would transform into a vertical band saw.
Then some time along the line I purchased a used PowerMatic 14” vertical BandSaw. That took care of my vertical needs. Along a W.F. Wells 9” x 16”horizontal BandSaw to increase my cutting capacity...
Cutting off several feet of I Beam to retrofit the Bridge Crane for one of my other garage..
I always admired the Marvel Vertical BandSaw and always on the lookout for one. Their cost is out of this world expensive for any home workshop. Then Three years ago I displaced the last two saws for a new Roll-in-Saw. The TF1420 is actually a horizontal band saw on a vertical frame. The tilt frame makes it easy to saw angular cuts. It uses compresses shop air to force the blade into the work. Has a mist spray coolant. Far less messy than a flood system. And actually takes a little amount of coolant to cool the blade and work. Surely it's not a Marvel. But the price is less than a decent used Marvel. Though the motor is three-phase. I ordered it with a built in 240 Volt single input VFD, Making the FPM blade speed quick and easy to change on the fly. Along with infinitely variable. Cutting capacity at 90° round is 14" Dia or rectangular 14" by 20"
Made in Cleveland Ohio sine 1940 and owned by the same family.
Spray mist coolant system
Motor and gearbox tucked away below. They wanted a nifty sum for a chip tray. I purchased a black plastic one and placed it underneath.
I cut the ends of a .080" blade for a precision protractor at 45° and 60° That I made for a long time friend and member from another board
Cutting off the stock from a piece that I made for the rear Axle replacement to my 1914 Cadillac. I started the cut using a cut-off tool in the lathe
I used one of my angle plates some parallels and a C-Clamp to hold the piece. This is the cut. Flush on one side and .010" on the other. I didn't even take time to use an indicator in the setup. As I had to face off the part anyhow.
