- Oct 4, 2011
- 727
So last weekend I got a new, to me, JET gold 14" band saw. I had been looking at their wood/metal working model but the price on this one, which is wood cutting speed only, was to good to pass up ($250.00). The guy that owned it took very good care of it. He sold it because he got a bigger saw. I will be changing it up to get lower FPS out of so I can cut harder metals. However, in the mean time I need to make a new throat plate for it. The current one has miles of room around the blade and I like mine very close to the blade.
So my question what is the best material to make band saw throat plates out of? In the past I have used aluminum and clear acrylic. Both have worked well. Has anyone made one out of steel or does this cause problems. Brass is also an option. One of the things this one has that my old smaller band saw didn't is it has a role pin on the lip that the throat plate sets on. The idea is that the pin fits in a notch on the throat plate and keeps the plate from rotating into the blade when you are cutting. I have never used a band saw that has this pin so I'm not sure how well it works (anyone have an opinion on it?) I was thinking of removing the pin tapping the hole and putting a pan head bolt counter sunk into the throat plate. This would secure the plate better but still make it easily removable.
Any thoughts on this or band saw upgrades in general would be helpful. )
Jeff
Jeff
