Band saw chip clearance device
Janderso
Jeff Anderson
H-M Platinum Supporter
Mar 26, 2018
8,666
If your horizontal bandsaw gets clogged with chips throughout the wheels and inside the cabinet, this may help/
It sure works well.
All my inspiration was from AGCB97.
The chips are removed before the blade enters the guides, wheels and housing.
Slot and air-passage dimensions?
Thanks for the great idea, mine is in the works right now everything is done except for the thru hole for the air and taping for the valve fitting. Just figured I'd get on it right away before the idea gets lost in my brain. Thanks again John
Good idea, and seems original. The canted wire wheel commercial machines use sure aren't very effective.
Oh, sorry. I just saw this.
The vertical air hole is 3/16". I used an end mill.
The gap is also 3/16".
This was a swag. It seems to work very well though. I got lucky.
