- Oct 17, 2018
- 966
Has anyone made or come across a ball turner for an Atlas/Craftsman 101.07403 lathe? I've seen lots of plans for ball turners, but the lathe I have doesn't leave much room for the tool, so this limits the ball diameter to less than 1.25". I'd like to see if there's something specific for these lathes.
The type I'd like to try and make is this one:
The cylindrical rotating part and the base plate have to be really thin (unlike the picture) to allow for turning anything bigger than about an inch in diameter. This doesn't seem like it will be abler to take the cutting forces, even with lighter cuts.
This one would probably work a little better, but I'm concerned about fabricating it. Specifically, getting the axle holes on the outer yoke piece concentric. They can't be drilled/reamed at the same time because the drill bit/reamer needs to be really long to go thru both holes at once. I'm sure I could get them close if I did them separately, but it seems even a few thousandths would be too much.
Also, I have lots of square tool bits and don't want to buy a a square broach and press to make the hole. I'm not sure I'm comfortable using a round bit (I like to grind bits using the tool rest and a round bit wants to spin). So that means making the C-shaped tool bit holder in two halves, or making the a slot for the bit and making the holes off center to line up with the center of the bit.
Anybody got any ideas, links, etc? I'd hate to reinvent the wheel. Thanks!
