- Mar 10, 2012
- 125
I completed this a while back because I needed a turner to make the half round washer I needed for a small machinist's vise I was making. I started by milling out the pockets for the bearing and turret to seat in on my mill/drill, and then turning the turret down on my lathe. The turret was supposed to sit inside the base, and rest on the bearing surfaces, allowing it to rotate on the bearing while being kept true by ID of the base.
Then I milled out the insert holder and drilled, countersunk, and tapped the holes for the tensioner screws in the turret. Finally, I turned the handle for it with the turner itself.
This is a less complicated version of the Hole's Creek version of the Steve Bedair Ball Turner. It didn't turn out to be as rigid as I would have liked (the turret was supposed to fit into the base with a lot closer tolerance. The result is that the flex in the motorcycle wheel bearing allows just a bit of vertical wobble at the cutting edge. Not much, but just enough to allow another line across the face of the sphere on the return cut. It's close enough that I can touch it up with sandpaper and jeweler's rouge, but I need to make another base to be satisfied. Thanks for having a look.
