- Apr 24, 2022
- 180
So, I understand how the surface speed of a ball mill approaches zero near the centerline, and how that hinders proper cutting action - much like facing. CNC units seem to use ball end mills all the time - I assume that is part of the reason for the insane spindle speeds. But for the rest of us mere mortals, how in the heck does one get any kind of decent surface finish with a ball mill? I have an application coming up, in A36 steel where I need to 'route' out a semi-circular channel in 5 places. 8mm carbide ball mill, 4mm total depth, roughly 0.200" in length.
So, what's the process to get a decent surface finish in this cut? (And no, I don't have sufficient material to drill & ream, then mill off half of the hole, unfortunately)
