Hi all. I need to make a set of wood turning tools known as beading tools. The attached pictures show the profile of the recesses that I need the cutters for. The tools themselves are found to ground to 45-60 degrees. I was going to buy a pre-made set but since I have a new (to me) PM935 I thought I would give it a try. I plan to make these out of various size HSS blanks. My questions are:
1. Do I want carbide 4 flute ball ends such as these: https://www.mscdirect.com/browse/tn/Milling/End-Mills/Ball-End-Mills?navid=2106252
2. Do I want to try pre-cutting the recess with a standard end mill first and the following up with the ball nose, try it will multiple passes with the ball nose only, or try a slow single pass with the ball nose.
Thanks in advance.
Thanks in advance.
