I don't have a bender. I wish I could bend some things like that. I carved them out of a block of 1018 CRS. My Burke Millrite is not operational yet so I did it the only way I knew how with what I had.
Band sawed the stock about 5/8" to long
Dressed the sides & ends on the Millwaukee tool & cutter grinder.
Drilled and bored the hole on the lathe.
Sawed and filed the slot
Sawed to length and rounded the end on the Belt sander.
[QUORrTE=Getaway;156672]I don't h a bender. I wish I could bend some things like that. I carved them out of a block of 1018 CRS. My Burke Millrite is not operational yet so I did it the only way I knew how with what I had.
Thought I would never get done.[/QUOTE]
- - - Updated - - -
Supper nice job!!just shows you with a little thought. You can make do with what you have
They look better than any bent pieces I have seen. Probably more work than you wanted to put into a simple tool, but hey nobody said this hobby was for the impatient
