- Mar 10, 2012
- 224
Before a world wide economy, bearing shops stocked bearings good for almost any use. High quality was almost standard. Today they can be made anywhere under familiar names at lower grades.
I found some engineering standards. ie CR3 (a clearance tolerance for certain applications) or ABEC1 (another standard for new construction). Doesn't really identify bearing longevity related to metal alloys used in their construction.
The only standards I considered were dynamic and static force numbers for bearing rating. Knowing these figures is a least a starting point.
Question is, how do you (HM members) identify the level of bearing quality you want to purchase, so you can use it again?
