"Balanced" Dog Plate...
Ray C
Nov 16, 2012
5,596
Here's a little project in the works. This is the second I've made because a friend liked the 1st one so much, I gave it to him. Now all the sudden, I want to make a precision cut and needed to make yet another one.
The old fashioned lathe dogs tend to run out of balance so here's a contraption that works rather nicely. In it's current state, it's not very safe but a side plates will be welded with holes to access the pinch bolts and the corners will be contoured. The main pillars each need a V-notch in the center. This one opens up to 4" and closes all the way down. This was just a quick test fit.
Construction and use are pretty straightforward...
Ray
Balanced Drive Plate 1.JPGBalanced Drive Plate 2.JPGBalanced Drive Plate 3.JPG
Balanced Drive Plate 1.JPG Balanced Drive Plate 2.JPG Balanced Drive Plate 3.JPG
