- Nov 27, 2012
- 7,912
Anyone have any experience with these? I had no idea Bahco even made bandsaw blades. They claim their tooth design allows you to cut various shapes, sizes, & materials with the same blade. They don't specify a tooth count.
Kind of sounds gimmicky to me but Bahco usually makes decent stuff. I'm guessing maybe it's a finer variable tooth count that will allow you to cut thin material at the expense of speed for thicker materials? If you're not familiar with Bahco, their tools are more popular in Europe than in the US with many of their tools not available here. They are owned by Snap-On.
Was looking through the Travers mailer I got for this month & they are on sale. They are made to order, drop shipping from Bahco is free till the end of the year. Sale price is $10 cheaper than what I pay for Lenox bi-metal blades. I normally use 6-10T the most on my 7x12 but I also use 5-8T, 8-12T, & 10-14T. I'm good on blades for a while but for $30 I'm thinking about buying one just to kill my curiosity if no one has tried them.
Brand: BAHCO
Problem: Different materials and cutting jobs require a wide variety of specialized blades in the shop.
Solution: A patented tooth design works across nearly all materials so you can save on storage space and decrease downtime.
More Cutting Time With Less Blade-Changing
Spend more time cutting and less time changing blades thanks to the revolutionary and patented tooth design of this highly versatile, general purpose band saw blade. Now you can quickly cut through metal, steel and even non-ferrous materials like copper, aluminum, brass and plastic, all without any time-consuming interruption. The incredible blade strength allows cutting of shaped materials like bundles, pipes, profiles and castings, and even contours, all without worrying about the teeth being stripped of their cutting power. M42 tooth design is heat-resistant to ensure optimum performance job in and job out.
BENEFITS
Save time and money by reducing blade inventory, operator labor costs and machine down time
APPLICATIONS
Brand: BAHCO
BENEFITS
APPLICATIONS
- For general purpose sawing in tool rooms, machine shops, maintenance rooms, fabricating shops & welding shops.
- Cut tool steel, mild steel, stainless steel, aluminum, copper, brass, wood, plastic, sheet metal, tubing, solids & bundles.
- Also cut pipe channel, angle iron, I-beams, H-beams & drill rods.
- Available in the following widths: 1/2", 3/4", 1" & 1-1/4"
- Number of teeth per inch is considered universal.
- Free factory direct shipping charges in the continental US only until December 31, 2019.
