Yeah I think so too. A bit stumped about how to get into it.G'Day Ropata,
sorry,
you have bad bearings by the sound and look
Looks like it is a 30 taper spindle. I also do not see how it comes apart. Perhaps take out the quill lock completely which may let the spindle/quill combination all come out together. Probably would need to remove the feed shaft and pinion as well. Also, what does the ring of socket head cap screws around the upper bearing hold?Not sure of the screw in the side of the quill but I would guess it is a guide pin for the R8 collet.
Yeah I'm really not sure about the ring of cap heads, there is a ring of 4 big ones which are really confusing as there is no joint in the casting or anything there. The small ring close to the top bearing must hold the assembly together.Looks like it is a 30 taper spindle. I also do not see how it comes apart. Perhaps take out the quill lock completely which may let the spindle/quill combination all come out together. Probably would need to remove the feed shaft and pinion as well. Also, what does the ring of socket head cap screws around the upper bearing hold?
I got the whole quill out. The top bearing I hope to remedy by tightening the spline sleeve. Do you guys think it's worth pulling the top bearings too?
