Back Gear Shims
cdhknives
Apr 12, 2013
562
When I pulled my back gears there were 2 stainless steel shims in place. In looking at the gear engagement, I think the back gear to headstock gear is loose, a lot looser than 'sheet of paper between teeth' engagement. Should I remove the shims to tighten the gear engagement or do they serve a purpose above and beyond just offsetting the back gears to the headstock?
That's weird. Back gears seldom show much wear as on most lathes they don't get much use. Unfortunately, the Headstock tech bulletin doesn't say anything about the shims. If it were mine, I would pull shims until the gears met the paper test and then turn the spindle through by hand a few times and if that seemed good, run it and check for noise changes.
Also, shims would work to loosen the engagement, not tighten it. I have no idea why they are there, but they look commercial and look made to fit. They are rectangular U shaped exactly the width and height of the headstock to back gear bracket mounting face.
My early model Craftsman 12", 101.07381 depends on shims to set the backgear spacing. The parts list has them as PN 10-261. If you remove the shims and the gears are too tight and you don't have a selection of shim stock readily available cut some replacements out of aluminiun foil or throw away AL pie pans.
Mike
Knives,
Look at any 10" or early 12" headstock parts drawing. The shims came in two thicknesses, .002" and .003". Current part numbers are 711-001 (.002") and 711-002 (.003"). Earlier part number was 10-261 (thickness not specified). You haven't said how many shims are in each stack from your machine but I would start with half of each stack and work in whichever direction is indicated by the results.
