I have been reading a few lathe books to get educated on lathe operation. The back gear operation and pin operation is easy to understand in the books. The books say that when the back gears are engaged a reduction of speed at which the mandrel is turned is obtained. It also states that when the back gear pin is engaged to the pulleys they also become locked to the mandrel thus giving a direct drive. I'm confused with the called back gear pin, isn't it the same as the indexing pin?? When I engage either on my machine one or the other or both together the mandrel becomes locked, can not turn chuck/mandrel by hand. At this point I'm afraid to turn lathe on because I'm afraid it would strip the gears.
My question; what is the problem, how to fix, should the back gears rotate on the shaft? Help
