- May 20, 2020
- 6
I just bought a craftsman 12in lathe 101.07383 after reading through some articles about the history of atlas craftsman lathes I determined it must be about a 1939
As it has the bronze "babbit" bearings in the head stock and a 12 in swing 42 in bed measured end to end and no power cross feed
seemed to be in very good condition just going over it and noticed a bit of play in the headstock and cross slide screws I believe the play in the cross slide may have to do with the brass nut I have tried taking slack out with the nuts near handles but when it feels good it has a few spots that seem to get tighter making it very difficult to apply even pressure while facing also seen the headstock bearing cap bolts are loose but can not find the proper way to adjust them for the "babbit" bearings
Ps I have worked with metal for years (cutting grinding and welding)and am currently a heavy truck mechanic but am new to machining.never worked with a lathe prior to buying this one .
