H
Hukshawn
Forum Guest
Register Today
Well, I decided to make a new thread in the right area. This is likely to be a long process. Hopefully not terribly expensive too. Wife is mad enough how much money as time I've spent on this already.
So, the First j-head column mill.
I played around with it and noticed it has some war wounds. I picked this up from a guy a few hours away from me who retrieved it as a bit f payment for work he did in a factory. I believe he was an electrician who also built conveyor belts.
I bought it for $1450. I think it was a fair deal.
The machine is filthy, but useable as is.
I like clean machines, but usually don't wind up cleaning them up before I use them. This time I wanted to clean it up first.
So, I decided to tear it down. Found some parts that could be replaced. Some bearings, the x table brass nuts, and found the quill feed doesnt work.
The worm gear is shredded.
Also can feel some broken gears inside the quill fine feed.
To be continued.
To be continued.
