- Apr 30, 2015
- 12,242
Just cut some 3/8"-16 threads (my first) on my MK2 Atlas and found that the tool was drifting slightly
to the right and back again with each revolution of the spindle. I discovered the 64 tooth
leadscrew gear had a slightly crushed tooth which was causing a tight spot once per rev of the screw. Apparently there was enough flex in the banjo to transfer some error to the carriage. The tip-off was the fact that the leadscrew TPI was the same as the thread I was cutting (16). I dressed the damaged tooth with a file and all is well.
Check your zamak gears carefully folks!
Mark S.
Mark S.
