Atlas th54
Tiberiusx
Jan 22, 2018
3
Hello, I have been resurrecting a th54 that I literally found in a field . One thing I’m looking at fixing up and replacing is the cross feed gear it’s 24 tooth and is the same one ( I believe used in traverse gearbox).
Can anyone advise the pitch angle etc.. for this ? I plan on printing it on a 3 d printer then ..go from there thks
45 degrees. I'm guessing that you're after the mitre/bevel angle for the gears that transfer power from the leadscrew to the crossfeed screw?
ie: these ones.IMG_20170805_154922.jpgIMG_20170805_162524.jpg
