Atlas TH-54 Restoration
jimmydubois
Sep 28, 2013
5
Bought this old Atlas from a buddy about 6 years ago, figured its about time to get her running again.
20130910_181002.jpg20130910_181019.jpg20130910_181035.jpg20130923_170543.jpg20130923_170548.jpg20130923_170747.jpg
20130910_181002.jpg 20130910_181019.jpg 20130910_181035.jpg 20130923_170543.jpg 20130923_170548.jpg 20130923_170747.jpg
Disassembled. Using Purple Power to degrease and Evapo Rust on small parts.
Apron disassembly
20131005_171609.jpg20131005_171623.jpg20131005_171643.jpg20131005_175618.jpg20131005_175635.jpg20131005_175710.jpg
- - - Updated - - -
Built an electrolytic rust removal bucket for larger parts.
Sorry for the sideways pictures, haven't figured out how to rotate them yet.
Reverse gear box
20131025_152557.jpg 20131025_152603.jpg 20131025_152618.jpg 20131025_152627.jpg 20131005_171609.jpg 20131005_171623.jpg 20131005_171643.jpg 20131005_175618.jpg 20131005_175635.jpg 20131005_175710.jpg 20130926_184348.jpg 20131005_171221.jpg 20131005_171232.jpg 20131005_171249.jpg 20131005_171305.jpg
Wow, that's going to be some restoration job. Your ambitious. I have a th54 too so if you need to know about something I can always go look at mine.
I agree with schor, that's quite a project. Mine was thoroughly caked with grease, dirt and swarf, though I had very little rust to contend with (just a few bolts mostly). It's a lot of work but the reward is well worth the effort. Hope you'll post some pics along the way. Good luck.
Allen
@Schor, thanks I will keep that in mind
@Aforsman, this one is caked with grease also; I’ve been pulling it apart and soaking the parts in Purple Power overnight, then scrubbing with a brass brush, working great so far.
As for the rusty parts the Evapo-Rust is a miracle worker, I'm amazed at how clean the parts come out. Haven't used the electrolysis bucket to remove rust yet, I'll post before and after pics when I do.
I plan to post pictures as I progress.
looks like you are going to end up with a nice lathe , gether done
Hey JIMMY
Man, can only admire U Guys determination and expertise.
If only we could ...........
Love to see progress pics
aRM
Had about an hour to kill this morning, so I worked on the lead screw reversing gear box.
Degreased and soaked in Evapo-Rust. The box itself has three oil holes that had been completely clogged with dirt, I ran a toothpick down the holes and followed up with a squirt of brake clean. I need to find a handle and get the detent ball and spring for it.
Unfortunately the gear box bronze bushing and gear are scored, due to lack of lubrication. Have about .007 play between the shaft and bushing.
Most likely will clean up the shaft and find a bushing I can press in and hone out, don't know if the housing will hold up though.
Started cleaning the carriage apron, the small gear on the rack feed unit is missing a tooth. I saw someplace, maybe it was on this forum, a guy that had replaced this gear.
20131026_102625.jpg 20131026_105926.jpg 20131026_105932.jpg 20131026_105947.jpg 20131026_105501.jpg
My handle was broke in the same way - found one on Ebay (about $15 from what I recall). I'm also missing the detent ball and spring, but it runs just fine without it - the friction between the teeth of the dog clutches keep it engaged while under power. Hope you can find a replacement for the broken gear without going broke :)).
Allen
