Hey all,
Figured I would check here before I did something that damaged my tail stock. I am trying to remove a "bearing", according to the parts diagram it seems to be a slip fitting. It says this is a bearing but it seems to also be a solid piece. The silver part in the picture below. Right now it is stuck solid. There seems to be a notch for maybe threading it in and out, but it is so stuck I can't really tell which it is. I was going to hit it with some PB Blaster and see if that did anything to loosen it up.
Can someone confirm for me if this is a slip fit or a thread fit? or something else?
Thanks, Philip
Thanks, Philip
