- Apr 10, 2022
- 27
Does anyone know the specs on the Atlas Pick-O-Matic drive gear 10-1213? (Or where I can find one?)
At some point in its life, someone removed the drive gear, leadscrew and all change gears from my newly acquired TH48. Otherwise, everything else appears to be entirely in tact. I am assuming that I will likely need to make one, or find an off-the-shelf gear and adapt it to accept the keyed leadscrew properly. If I do need to make one, having the dimensions/sketch would be rather helpful.
Holding off on getting a replacement leadscrew until this mystery is solved. Especially since the manual suggests that the head-end of the leadscrew needs to be cut off at the shoulder.
Thanks,
Blue
Thanks,
Blue
