- Mar 26, 2014
- 211
Looking for
Looking for some info on the motor on my Logan Lathe, model 200. I have a 1/2 HP Atlas motor, Cat 2530A, 110v, 1725 RPM, Frame 118C. When I turn it on the motor hums. If I turn it by hand a couple of times it will run. The voltage with motor off is 121v, on position 104v and the motor hums. If I start it by hand the voltage goes to 117 with it running. Could it be a capacitor?I'm not sure what parts I should order. I will mention tat it started fine in the po's shop. Any help will be greatly appreciated. Thanks
