- Nov 15, 2020
- 143
Does anyone know what the belt tension should be for these mills? The manual says it should be "just tight enough to prevent slipping".
I currently have ~7/8” deflection center in the middle of the spindle belt, and ~3/4" deflection in the middle of the motor belt. I'm ok normally but do run into slipping on heavier cuts sometimes, so wondering if others normally run tighter. I have the original pulleys on it and a 1/3 HP motor which I plan to upgrade to a 1/2 HP one of these days.
