- May 20, 2016
- 41
I have a question that is a bit above my knowledge/comfort level for deciding on my own. I recently bought an Atlas MFB and am in the middle of cleaning it up and seeing what I have and what I need. One of the things I know for certain I need is the counter shaft two groove pulley. That pulley is Atlas part number M1 80B. Atlas nor Sears have any of these pulleys left. I found a “maybe” online today but it was a bit more than I am willing to pay.
My plan is to use two single pulleys and change them out when the need arises until the correct part comes along. The drawing that Clausing emailed me shows the Atlas pulley having an outer diameter as 2 3/8 for the small and 3 ¼ for the larger side of the pulley with a 5/8 bore. 3 ¼ was easy to find but 2 3/8 not so much.
My intention at this time is to go a bit smaller than stock for the smaller pulley, I’ve found some that are 2 ¼ diameter. My question concerns the size of the pulley and the change in the speed of the head-stock. Will running that much smaller pulley on the counter shaft. Change anything enough to hurt anything in the back gear, the chang-o-matic, or the auto feed? I would think that slowing down slightly wouldn’t hurt anything but I’d like to get some opinions.
Thanks in advance.
Eric
Thanks in advance.
Eric
