I just acquired a vintage horizontal mill, which came with no tooling other than a single 1/8” wide cutter. I did get a 1” arbor for it along with a set of spacers. The arbor has a 1/4” keyway in it, the cutter has the same sized keyway in it, but the spacers do not have a keyway in them. So there is a problem that I cannot put a key in the keyway to hold the cutter in place, as the spacers have no keyway in them.
I see three possible solutions:
1. Don’t bother with a key, just tighten up the spacers hard and hope they will prevent the cutter from spinning.
2. Use a piece of key that is relieved part way along its length on either end, such that the relieved sections would fit under the spacers on each side of the cutter, while the remaining center part of the key will support the cutter.
3. Broach a keyway in two of the spacers. The spacers are only 3/16 thick however so if I put a .125” deep keyway into them there is not much material left. A variation on this is I could make some thicker spacers and broach them. Plus I have no way at present to broach.
I welcome any insight or suggestions on how I should proceed.
