- Dec 25, 2011
- 10,552
Attached below are the current version of the dBase .DBF file (with the .MDX file that I don't think that any of the Excel or Access clones will use). These files are updated sporadically as new information surfaces. Microsoft Access and most of the clones of Excel will open the .DBF. However, not many of them will save it as a .DBF. And few if any will use the multiple index file. So on that subject, you are on your own.
Unless I forget, prior to each successive upload, I set the index to MODEL + SER_NR. That at least keeps the Atlas, Craftsman and AA separated and the lathes separate from the mills and the shapers.
The files are also maintained in Downloads. As of 2020/09/16 there are 758 entries. I don't always remember to update the two below when I update Downloads. If you do not have dBase IV or later, the .DBF file can be opened with Access or with Excel and most of its clones. In which case, don't bother to download the .MDX file.
EDIT 2020/09/16 758 Entries.
