It lists the gears as all steel. Atlas gears were a zinc alloy not steel. So if these are steel they aren't original , we're custom made ,or my go to a different lathe. Double check before buying.
The steel gears are stronger and will probably last a lot longer than Zamak gears. My Zamak gears have a significant amount of wear on them. Funny, for all the times I've driven through Penryn, I've never had a reason to stop. Now that I do, I'm 1,000 miles away.
