A milling vice (10-502) from an Atlas TH42 has been offered to me for use with my Clausing 4800. This is also listed as an option on the original owners manual. It seems that a tapered post is needed on the compound where this will attach along with 2 hardened pins with tapered edges to secure it. My lathe does not have the tapered post on the compound as the cross slide is held by 2 nuts on its swivel face and no hardened pins. So my question is how can this milling vice still be securely attached to my compound without the tapered post or what is needed to make this work?
Thanks much, Tom
Thanks much, Tom
