- Feb 26, 2013
- 128
Greetings All-
As the Atlas mill rebuild continues I find that the bushings on the spindle and counter shaft are worn to varying degrees. I would like to replace them and it looks like McMaster Carr has "Oil Embedded Sleeve Bearings" (often called "Oilite" bearings) that come in the sizes that I need. These are a oil impregnated "Porous Bronze" bushing. They look like a good match for this application.
What do you think? Is this the way to go or is there a better option? Any comments or suggestions on the best replacement for these bushings is greatly appreciated.
Thanks!
Thanks!
