I have recently acquired two Atlas Horizontal Mills. One was sold as a parts machine and the other as a working version. It turns out that the "working" version was not in working order and that the 2 of them are different models. One is a "MF" and the other is a "MFC". So I looked to the "parts" mill and found that I had everything I needed to put that one together, it is now in a working state after making new Arbors for it in both 7/8" and 1" sizes. I am now hoping to get the other one working as well and am looking for a few parts to complete it.
The info I am hoping for here concerns the Spindle Pulleys, The MF has 3 belt slots and the MFC only 2. The older MF 3 Slot version is broken and I am hoping to find a replacement. I called Clausing and as expected the part is no longer available. I got the Drawing for it and am toying with the idea of making one but am not very experienced at machining so not sure that is wise at this time at least. So the question I have is I understand that the earliest versions had a 4 position pulley like the 6" Lathe. Since the spindle seems very similar on the mill and the 6" lathe does anyone know if the Lathe pulley will fit the Mill?
