- Jan 2, 2014
- 53
Here I am again.
Question regarding gear teeth clearance.
While checking out my 'new to me" Atlas 10" QC 54 last night, I noticed what looked to me to be too much clearance where the gears mesh
up. The gears are not lubricated properly, and I have that question up for opinions on another thread.
Anyway, how do you tell if the gears have the right amount of clearance, or too much? Some of the gears have adjustment for them, and
some do not. Looking at the Tumbler Assembly, when it is positioned from lo to hi or visa-versa, the gear that is supposed top be engaged
has ( what looks to be) too much teeth clearance. I you move/slide the "index plate" up or down to get tighter tolerances on that gear,
the other gear will have too much clearance when position is moved to use the opposite setting, i.e. hi or lo. I hope that description was
understandable. The gears look to have very little wear, so I do not believe it is a "worn teeth" issue.
The gear noise when running is almost deafening. Hopefully, the lubrication issue will take care of some of that noise.
Are these machines normally that noisy from the gears?
All suggestions appreciated.
Regards
Jack
Regards
Jack
