- Jan 2, 2014
- 53
Well, this is my first post, so be gentile on the newby.
I realize that this is a very elementary question, and the subject has probably been beaten to death. BUT, I have read and received different
opinions on the Atlas "ZAMAK" lathe gear lubricant. I would like to start off with the right lube.
I just got my (new to me) Atlas 10" QC54 lathe in my man cave. I bought it at an estate sale. It has been cleaned up exceptionally well.
The gears were all cleaned so well, that there was no old grease or lubrication of any kind on them. The only NEW lube, was one tiny thread
of what looked like graphite grease around the perimeter in the center of the teeth on each gear. This was/is not nearly enough lubrication.
The gear noise is almost deafening when running.
The Atlas book says to use 122 grease. A fella on you-tube says motorcycle chain lube works great. Others say to use 40 to 60 weight oil,
that grease will catch and hold chips. Don't you need to use a lube that will NOT sling off?
I am sure that there are a lot of lubes that would suffice, but what is the best to use on my "new to me" Atlas?
All suggestions are greatly appreciated.
Regards
Jack
Regards
Jack
