I converted my 12” bench top lathe to a under drive cabinet model, and mentioned in my intro and refurb thread here:
…when I bought the lathe cabinet surplus, I got everything except the 2-step countershaft and motor pulley. Seems the folks on eBay think the large pulley is worth $150 and the motor pulley $60-$70. With shipping that would be $260+ and that aint happenin for a couple pulleys. I looked/watched for 3-4 months and made offers but no dice so I decided, screw it……..I’ll make them…..it’ll be a good first project to commission the lathe. I didn’t have any suitable stock but do have a home foundry and do some lost foam casting which makes the stock essentially free and saves machining time so I made some lost foam patterns for pulley blanks on my pin router.
Here are the resulting castings.
There is a thread on the casting project is here. You may have to join the forum to view the pictures.
….anyway, the castings are designed to be about .060” material rich in the OD, faces, and grooves. Not quite sure how I will machine the large pulley. I’m thinking chuck on the largest OD with small step outward, bore the shaft, machine what features I can, remove the pulley, make an arbor and press it into the shaft bore, re-chuck the pulley on the arbor, machine the last/larger groove and face. Sound reasonable?
The odd thing about this whole endeavor, I couldn’t justify paying the eBay prices for these pulleys but on the other hand, I also couldn’t justify selling the ones I made for the prices being asked eBay…..just stubborn I guess.
Best,
Kelly
New Caretaker of Two 12” Craftsman Lathes
Hi all, first post here. I’m the new caretaker of two 12” Craftsman lathes, one with a 42” bed and the other 54”. Though they recently came into my possession they are well known to me. The 42 is model 101.07403 number SN 16014 and the 54 is model 101.07403 SN 22500. The only place I’ve found...
www.hobby-machinist.com
Lathe Motor and Countershaft Pulleys
As part of the lathe restoration project I started here, http://forums.thehomefoundry.org/index.php?threads/dro-mount-for-lathe-restoration.1397/ and...
Best,
Kelly
