The 6" might. The 6" steady rest has a capacity of 2-3/8" diameter. However, the short bed (a nominal 18" between centers, and less than that with a chuck mounted) won't leave much room to maneuver a boring bar, even if you pull the tailstock off. The 10" or any of the 12" would. They were made in lengths up to a nominal 36" between centers. The steady rests for 10" and 12" have a diameter capacity of 2-7/8". The reason that I mention the steady rest is that the spindle bore of even the 10" or 12" is only 3/4" diameter. Even if you buy an 8" chuck and can find one with a greater than 2" ID, that only buys you the work piece length for about three parts plus however much you can get away with sticking out of the chuck (probably 4 at a guess). With a steady rest always supporting the working end, you could start with an 18" long tube or a little longer, always have the parting off point close to the support, and move the steady rest toward the headstock every second or third radius and cut. And you should acquire a set of roller jaws for the steady rest.
One comment - do the ID radius before you part off. Otherwise you'll find out the hard way that holding parts with lengths significantly less than their diameter is tricky.
Otherwise, you need to look at a lathe with 2-3/8" spindle bore. Although you could conceivably find such a machine cheap and still in good enough condition to use without major repairs, tooling and accessories for it are typically going to be much more expensive and harder to find than those for the Atlas.
But in any case, whatever lathe you buy, be prepared to spend at least what you paid for the lathe on tooling and accessories unless you are very lucky and get everything you need as part of the purchase deal.. In this regard, price and availability of accessories is generally better for the Atlas than the same items made for the 4 or 5 other comparable US brands because many more of them were sold. All of the comments in paragraph one also apply to anything made by Clausing, Colchester, Logan, Rockwell, or South Bend that has less than a 2+" spindle bore.
