- Feb 14, 2016
- 121
Hi, first, I hope this is in the right place. If not, forgive me! I've had this little thing for about a year and I have really barely used it. Just recently I did some work on aluminum and it performed quite well. Turning steel makes a pretty bad grinding noise and I can see the work deflect as I make a pass on it. I assume the work is deflecting and not the tool.
Today I was working with some aluminum again. Here's a picture of the setup:
I was reducing the OD of this plate and as I was making chips that same bad noise came back and then the lathe stopped turning. The motor was spinning and the belts were moving but the head stock(?) wasn't moving. I shut it off and was able to spin it by hand. I turned it back on and it worked for a bit but then kept stopping on me. It wasn't binding on the cutting tool; it would even do it if I wasn't making a pass.
I just would greatly appreciate some help getting this thing in nice working condition. Just a couple days ago I ordered the tooling kit from the little machine shop with the QCTP, drill chuck and various tooling for about $200. I was using old tooling that came with the lathe this whole time. So I'd like this little lathe to work for me
I think I need new timken bearings but am unsure what to get. Or maybe my belt tension is way wrong?
And help is appreciated! If you need more info let me know!
Thanks,
Dave
Thanks,
Dave
