Hi all,
Long time lurker, first time poster...
I picked up a Craftsman 12x48 (54" bed- 07403) lathe a few weeks ago for $400, which is a very good deal in AZ where there is hardly any machinery. Junk goes for a premium.
I didn't have time to research much before having to make the purchase. I called and was at the owner's home within 2 hours and he had two other individuals waiting to come after me. I believe the guy, as I've been shopping for something for almost a year with very few "hobby lathes" showing up...mostly the big stuff at $3k+.
At the price I decided to grab it as the collet set itself is about $200. However I discovered after being told it had a "complete set of gears" that I was missing about 7-8 gears and a few other tidbits. But the gears could add up quickly.
I made the mistake initially to buy used on that auction site only to find out later a brand new steel gear could be purchased cheaper from Boston, via Amazon Prime even.. (Tip for anyone else - check out Boston Gears FIRST!!!! The price on the 48T and smaller are about the same price as used Zamak on Ebay, hope that helps.)
That's the background, now the issue....
The combo gear, 16/32, on the tumbler, a unique gear, not a catalog gear......cheapest I can find is about $70 used Zamak on the auction site. However, I've figured out that I can buy Boston Gear NB32 and NB16B, cut off the extra hub (about 1/2") and that should get me what I need while still being cheaper than buying a used Zamak part in unknown condition.
Here's my question.
Being that this is a "combo" gear I wanted to know if they need to be "fixed" together, or can they both freely rotate on the same axis, independently? I don't' have all my gears yet so I'm having a hard time visualizing this.
The threading chart is a bit confusing but it looks like the 32/16 is just "flipped" for the different scenarios, not used for one gear, the 16 for example, to drive the 32 and vice versa being that they're locked together, if that makes sense. If this is the case, they shouldn't need to be fixed together, which would save me some effort.
If in fact they need to be fixed together, is there any other suggestions other than tapping both gears and using a type of set screw to hold them together?
And BTW, I've already bought the NB32 and NB16B gears, so I'd like to use those. I realize I could have bought the GB32 and used the bushing, but this seemed easier, and one less part. (There is no GB16, as that would solve my problem altogether = GB32+GB16 with the keyway bushing.)
Thanks in advance for any help!
Here's my question.
