May have to get a SLIGHTLY larger piece of stock and make it myself. What is material for atlas craftsman 12 in model number 101.07383 gib? Steel or brass?If you can't find one it shouldn't be that hard to make.
Been thru drawings did not see what I need. Is the part steel or brass? Thx@Selbyrk, since you are a premium member (thank you for supporting the site) you can access the downloads section. There are drawings for Atlas gibs in there, you'll just have to check to see if one fits your 12" model. Otherwise, you can learn enough about how Atlas designed them to scale up and reproduce the part.
