Ok couple questions here.
1. What is the thread of the screw that holds the lead screw on by the bearing? It appears to be 20 TPI but seems to be smaller than 1/2".
2. Going to hook up a auxillary motor like Fred Miller shows and Tublacain and others on you tube to run the power feed so it can be ran slower. What are the best ways to attach the shaft to the motor. The answer to question #1 will help this a lot.
Thanks in advance.
Shawn Agne
Thanks in advance.
Shawn Agne
