- May 27, 2011
- 49
I owned this lathe in the 1980s into 2004. It was very tired by that time but it ran and I needed a smaller lathe than my Von Wyck 15x60. It came only with a 3 jaw chuck that ran true enough. I sought out and found the spindle nose adapter for 3C collets and snagged a full set of South Bend 3C collets. With collets this old lathe made some accurate parts. I did not have the gears for threading but the previous owner had a new half-nut mfg out of beryllium copper (he worked in aerospace).
At some point the tiny spur gear that moved the carriage broke a tooth. So I made a lever feed for the carriage with 3 different holes for "feed speed:". It worked so well I never bothered to hunt up a new gear. I couldn't thread with it anyway.
The spindle bearing wasn't bronze or ball bearing. It was babbit (not cast iron). There were brass shims under the bearing caps. If you adjusted the bearing too tight it would seize up the spindle if you ran it too fast and forgot to oil the dang spindle. I put back that one shim so it didn't seize up again. This lathe had the Craftsman tag on the back of the bed. I don't know how old the lathe was. The patent date is 1933.
After using this lathe for many years and I've run other lathes my opinion of Atlas lathes is positive. They're a darn good lathe though I define darn good meaning "light duty" though that also can mean many things to many people. I would've never shied away from an Atlas in better condition and would prefer the one with Timkin bearing headstock. This lathe is still in use making parts in Ohio.
1970 & 1979 took tool machine engineering at Los Angeles Pierce College. Had a couple/few jobs making chips but mostly just a home machinist.
Fabricated a 3C drawbar out of 1/2" pipe. The collet thread was done separately and silver soldered to the draw bar. Piece of delrin as a thrust bearing and a 2" diameter aluminum handwheel. Just like downtown!
While I had a vertical mill at home I couldn't pass up this Atlas milling attachment at $25 at a use machinery store in Los Angeles.
