- Dec 27, 2014
- 4,093
A new to me lathe, it has no Zip codes on it, so it must have been built before 1963. I has no wear on the ways, I had to remove what may have been cosmoline from the lead screw and the gears.
Anyway, I was really dissatisfied with the solidity of the lantern tool post.
I put a dead center in the headstock taper, measured the distance from the center to the top of the compound. Wonder of wonders, it is pretty darn close to .750. I rememberd some carbide tool holders I'd squirreled away and put one on the top. It looked good, how to hold it down. Well I still had the lantern, wondered if I could use it. I built a stack (two 3/8 bits) opposite the lantern and put another through it, clamped it down. The whole thing is rock solid. Not only that, but I've got threading inserts for this holder.
Has this been done before?
The aluminum shim under the tool is to make up of a 1/16 I milled off of it years ago.
I have other 3/4 tool holders for both right and left and positive and negative inserts, too.
