- Apr 12, 2013
- 562
I took apart my very dirty and neglected 4-jaw that came with my grandfather's lathe. IT came apart and went back together pretty easily, and a toothbrush + WD-40 took care of the gunk. Two questions:
1) The set screws on the back that hold in the U shaped retainer for the adjustment screws were loose. When I tighten them, the jaw adjustment screws are very stiff. Should they be snug (in which case I have a problem) or left loose?
2) One of the jaws has a different, much finer and smaller in diameter, adjustment screw. It is also a duplicate #4 (missing #2) so I assume at some point one jaw got lost or damaged. The smaller adjustment screw rattles around a bit, but once torqued down seems tight enough. Problem or not?
