I am “restoring” an early Atlas Metalcraft lathe (mostly repainting, but, given the scope of rust removal/surface prep plus other things on my to do list, this may be called a restoration). I already have a thread about it, which started with my chuck question and then was taken sideways (by me ). I thought it would be better to have separate threads for separate topics, hence this post.
Anyhow, after looking at the Metalcraft model photos, I realized my Babbitt bearing “caps” (that is, the parts containing the upper halves of the bearings) may have been reversed at some point: the oiler covers in middle should be hinged in the back, but the hinges on mine are facing the front of the lathe. I suppose the main question is how much the lathe was run with this setup so that it could have some effect on the bearings; naturally, I have no idea, as I just bought it.
The spindle (and, obviously, the caps) are now off for repainting. Trying to figure out: when I reinstall the caps, should they be in the (reversed) position that existed when I got the lathe, or should I orient them the way they were supposed to come from the factory? Any suggestions would be much appreciated, as I’m not sure what would be the best course of action - seems like there are pros and cons either way.
