- Dec 13, 2016
- 164
I’ve acquired an Atlas 7B shaper with a couple of issues. The ratcheting gear is wore out and someone tried the pinning fix to the shaft. I plan to machine a new gear and shaft. The motor is not the original and was tack welded to a mount plate. At highest speed pulley the motor arcs. I was wondering if anyone has OEM data plate specs or if anyone has replace the motor, what did you go with.
Thanks in advance for your help.
Will
Will
