I was wondering if anyone had a copy of the instructions that came with 760 model. I recently acquired one, and was curious about the purpose some of the holes in the bar that connects to the cross slide. Three of them have small screws that appear to set the elevation, and then there are the two holes in the centerline of the bar who's purpose doesn't readily spring to mind. I've done a search for the instructions but I have only managed to locate the 700 model instructions.
Also, if anyone has the dimensions of the little guide block that has the dovetail and slot for the bar, mounts to the cross slide, I would really appreciate hearing from you.
Terry
Terry
