- Dec 25, 2013
- 31
Anyone ever try to swap out the tool post compound assembly for on from a different lathe? Not only does the original like to break, but the T for the tool post holding screw is not only weak, but allows a LOT of flexing! Would like something ~the right height that could be used (even with a different cross slide base) that is a solid top that could be tapped so the tool post could be screwed to it. It seems like that would give the maximum strength, and not flex so when a deep bite is needed.
Any ideas or comments appreciated. (exc the usual "why do..."
