- Oct 10, 2018
- 545
TLDR...
What could be causing stock in my newish 4-jaw to wobble 25-30 thous when projecting just 2.5" beyond the jaws? Bad chuck? Bad spindle bearings? Something else?
Long, possibly meandering story...
So, my little Atlas 618 lathe has had a hard life these past 75 years. There are deep scars to the front of the compound where the chuck has crashed. Hard. Multiple times. I believe the spindle is bent. A drive centre or an end mill holder in the morse taper socket of the headstock spindle wobbles by about 3 thous near the spindle nose. The wobble gets more pronounced when I measure further out from the nose.
BUT, I don't understand why the 4-inch, 4-jaw won't hold work true. The backing plate for the 4-jaw was machined to fit the chuck on the lathe. It ought to be true to the real rotation of the lathe, no? I actually took a fresh cut off the face of the backing plate today. I used marker to ensure that I cut the entire surface that the chuck body mounts to. Despite this, a dial indicator showed that fresh face was out of true by about 1/2 thou or a little more!?!
I'm guessing that the spindle is running differently when there is tool pressure or not. I would like to add more preload but I can't get the collar (part M6-32, per the diagram) to turn any tighter. The end of the set screw that is supposed to be in that collar is all buggered up and the lead shot is long gone. The whole collar has been chewed up with locking pliers in the past. Nonetheless, it is as tight as I can get it.
Back to the 4-jaw. After taking the fresh facing cut, I reassembled the chuck body to the backing plate and put it back on the lathe. All mating parts were cleaned. The body of the chuck runs out less than 2 thous whether measured close to the backing plate or out at the jaw end. That makes sense to me since there is a tiny amount of play between the chuck body and the registration boss on the backing plate.
I then dialed in a piece of 1 inch drill rod in the 4 jaw and got it centred within a thou near the jaws. This is when I found that I still have relatively large runout just 2.5 inches out from the jaws. I measured it at about 30 thous on the first test. In case the stock was bent, I rechucked it at 180 degrees to the first attempt. The runout then measured about 25 thous.
BTW, if I alternately press and pull on the projecting workpiece, I can move it about 3 thous in each direction--6 thous total movement across the bed. That seems like a lot but no where near the 25-ish thou wobble.
I guess it is possible that the chuck jaws do not hold the workpiece in line with the body of the chuck. The chuck was from Shars and was pretty inexpensive. Is it really possible that it was that badly made? Is there any test I can do to determine if the chuck is at fault?
I do plan to upgrade to a better lathe but I'd still like to understand this problem better. Thanks for any suggestions or pointers.
Craig
Craig
