- Nov 18, 2012
- 1,352
I have an Atlas 618 that I use for repairing and making clock parts. I have noticed for some time that when I am trying to locate a centre drill on centre of a shaft that there is some side play in the tailstock, before I lock it down.
I have never touched the gibs in the 40 years I have owned it, so decided to see if some adjustment was required.
To start I set up a dial indicator to monitor the movement of the tailstock just close to the quill. With the tailstock not locked and I pull to the front and to the back I get a few thous of play. I messed around with the gibs and still no improvement. So next I moved the indicator down to the base of the tailstock close to the ways. No movement.
So it appears that the compliance is between the base of the tailstock and the main body. The offset set screws are as tight as I can get them, but there is still some movement between the base and the upper body.
Have others experienced this, and is there a good fix?
Thank you
David
Thank you
David
