- Oct 10, 2018
- 545
Hi:
When I face stock with my Atlas 618, the resulting surface is slightly convex. For example, I just faced some 1.25” aluminum and when I hold a straightedge across the newly cut face, it rocks every so slightly. I can get the feeler gauges out to measure it but I would guess a couple of thous.
I think my technique is good. I’m using the cross slide with the carriage locked to the ways. Don't think the compound is moving since this happens repeatedly. I also drilled a centre hole in the stock so it is not a nub left by being a touch off centre.
Does this mean that there is uneven wear in the cross slide dovetails? The gib does have obvious rub marks. How would one compensate or fix this?
In one of Keith Rucker’s videos, he said that a properly set up lathe should leave a an exceeding slightly concave surface. On the order of 1/2 thou over the working radius (8 inches in his case). This is so that faced parts will stand straight on a flat surface. Mine would wobble somewhat.
Craig
Craig
